With the Mailchimp data source connector, you can pull all data related to your email campaigns, such as email campaign details, industry, time, and A/B testing details. To get a full view of your marketing efforts, combine your Mailchimp data with your other marketing platforms.
Once you’ve connected to Mailchimp, you're ready to create your first query in Google Sheets, Looker Studio (formerly Data Studio), or Excel.
When connecting to the Mailchimp data source in Looker Studio, you must select a query type to use. The query type defines what sort of metrics and dimensions are available.
- Automations: Returns automations. Does not include customer journeys.
- Automation emails: Returns individual emails in a classic automation workflow.
- Lists: Returns Mailchimp lists, also known as "audience".
- Campaigns: Returns campaigns from your Mailchimp account.
- List activity: Returns daily aggregated activity stats for your list. For example, view unsubscribes, signups, total emails sent, opens, clicks, and more, for up to 180 days.
- List growth history: Returns a summary of the month-by-month growth activity for a specific list.
- List locations: Returns locations (countries) of subscriber lists.
- List members: Returns members of a specific Mailchimp list, including currently subscribed, unsubscribed, and bounced members.
Try these queries
See open rate of your emails
Take a look at the open rate of the emails you sent out with your campaigns this month.
The "Open rate" metric shows the number of unique opens divided by the total number of successful deliveries.
In Looker Studio, use the "Campaign" query type.
- Set the date range to This month to date.
- Select the Open rate metric.
See number of members on your mailing lists
Fetch all your mailing lists with the number of active members in them.
The "Member count" metric shows the number of active members in the list.
In Looker Studio, use the "List members" query type.
- Select the Member count metric.
- Select the List name dimension to split the query results by list.
See sent emails, opens, and clicks per campaign
Explore how many emails you sent for a campaign and how many times the recipients opened the email and clicked on it.
The "Emails sent" metric shows the total number of emails sent for this campaign, and the "Unique opens" metric shows the total number of unique opens. The "Total clicks" metric shows the total number of clicks for the campaign.
- Select the Emails sent, Unique opens, and Total clicks metrics.
- Select the Campaign name dimension to split the query results by campaign.
- You might encounter this error when pulling data from Mailchimp in Supermetrics with either Google Sheets or Looker Studio: Incompatible fields: IllegalDimensionMetricCombinationException. To fix this error, follow these steps.
- If you see errors relating to quotas, or "daily query quotas", read this guide.
See the Supermetrics blog for the most important email marketing metrics.
