Follow these steps to connect your Ignite data to Supermetrics and use your data in Google Sheets, Looker Studio, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your Ignite account, you need a client ID and client secret from your contact person at RealEstate.com.au.
- Campaigns: Measure the performance of your property campaigns.
- Under Data source, select Ignite.
- Enter your client ID and client secret.
- Navigate to Ignite and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Ignite requires authorization to connect to data").
- Select the query type, and click Next.
- Click Select data source.
- Select the Ignite data source.
- Fill in the query details.
- Hover over the Ignite data source, and click Connect.
