Learn how to connect your IQM data to Supermetrics.
You'll need an IQM account with a username and password to connect.
Query type
- Campaign performance: Measure the performance of the campaigns you manage with IQM.
- Under "Data source", select IQM.
- Enter your IQM username and password.
- Navigate to IQM and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "IQM requires authorization to connect to data").
- Click Authorize.
- under "Data source", select IQM.
