Connect Yext to Supermetrics to start pulling your search data seamlessly into your reporting.
To connect Supermetrics to Yext, you'll need an app and an API key.
- Log in to Yext and open your dashboard.
- On the left-side menu, click Developer and then Developer Console.
- Click + Add an app in the top right corner.
- Enter a name for your app ("Supermetrics", for example) and click Create app.
- Click the API Credentialstab and select these permissions:
- Analytics: Read-only
- Administrative: Read-only
- Click Save.
- After saving your app, navigate to API Credentials and then API Keys.
- Click the eye icon to show the API key.
- Copy the API Key. Be careful to keep it secure.
For Excel users
- Click Create query.
- Under Data source, select Yext.
- Give your Yext login a memorable name under Account Name.
- Enter the App Key in the Yext API Key field.
- Navigate to Yext and click Try.
- Click Authorize.
- If you're connecting Yext for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
