Follow these steps to connect your Shopify data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
There are two ways to connect Supermetrics to Shopify:
- From your Shopify store
This is the recommended way of connecting your Shopify store to Supermetrics with an easy-to-follow guided setup. - From your data destination
You can also go to your data destination and connect to Shopify from there.
Check below the prerequisites for account types and permissions related to Shopify and store connections.
Three types of Shopify accounts can connect to Supermetrics:
- Store owner
- This role has full access once it's connected to Supermetrics
- Staff
- See "Granting permissions" to learn about the permissions this role requires
- Collaborator (Shopify partner)
You can confirm a store's owner by logging into Shopify and navigating to Settings → Users and permissions. You'll see the store owner's name at the top of the page.
Collaborators have to follow a different set of instructions to connect. Learn how to connect a Shopify collaborator or partner account to Supermetrics.
Shopify store owners can add staff to their Shopify store. Learn how to add a new staff account or edit permissions for an existing staff account, including giving them permission to use apps like Supermetrics.
- To give a staff account access to Supermetrics, open the Permissions menu in Shopify, and then click Apps and channels. Supermetrics should be listed with any other apps linked to the store.
- While all store owners can link new apps to a store, staff members need specific permissions ("Manage and install apps and channels" and "Approve app charges").
- Additionally, owners must grant each staff or collaborator account these permissions before they can connect to Supermetrics:
- Home
- Orders
- Draft orders
- Products
- Gift cards
- Customers
- Reports
- Dashboards
- Marketing
- Discounts
If you want to pull data for multiple Shopify stores, you'll need to repeat the authentication process for each one.
Once you've completed authentication for your first store, reauthenticate your connection using the name of your second store. Repeat this process for each store.
Connect to Supermetrics from Shopify
It's recommended to connect to Supermetrics from your Shopify store. This method offers an easy-to-follow guided setup.
Step 1: Install Supermetrics app to your Shopify store
- Find Supermetrics in the Shopify app store. Supermetrics is available in the Store Management category.
- Click Add app.
- Review the permissions, and click Install app.
After installation, the Supermetrics app shows in the left sidebar under Apps.
Step 2: Create connection to your Supermetrics team
- Go to the Supermetrics app in your Shopify store.
- Click Create or refresh a connection.
- Login to your Supermetrics account.
- Select the team you want to connect to Shopify with, and click Continue.
- Click Back to Shopify.
Step 3: Connect Shopify to your data destination
- Select your data destination (Google Sheets, Looker Studio, or Excel) from the list of reporting platforms.
- Follow the instructions for your data destination.
If you need to refresh your connection and reauthenticate, click Create or refresh a connection in your Supermetrics app.
Connect to Shopify from your data destination
Follow these instructions to connect to Shopify from Google Sheets, Looker Studio, Excel, data warehouse destinations, Power BI, and the Supermetrics API. You can also connect to Shopify from the Supermetrics Hub.
- Under Data source, select Shopify.
- You'll be asked to install our app the first time you connect. Click Install app to proceed.
- Enter your store's name. The store name is the first part of the store's URL. For example, for mystorename.myshopify.com the store name is 'mystorename'.
- Enter your email, click Next, enter your password, and click Log in.
- Select the accounts you want to include in your reporting.
- Navigate to Shopify and click Start free trial.
- You'll see two buttons saying Authorize. If you're using Supermetrics for the first time, click the left-hand one and log in with the Google Account you use with Supermetrics.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Shopify requires authorization to connect to data").
- Select the team with the connection you want to use with Shopify.
- Click + Create transfer.
- Select the Shopify data source.
- Accept the agreement.
- Click Authorize with Shopify.
- Click Submit.
- Click Save.
- Click Create new.
- Select the Shopify data source, and click OK.
- Click Create transfer.
- Click Select data source.
- Fill in the query details.
- Hover over the Shopify data source, and click Connect.
- Shopify: Query setup guide
- Shopify permissions guide
- How to edit the time zone for a Shopify query
- How to reauthenticate a data source in Looker Studio, Google Sheets, or Excel
- How to reauthenticate a data source in data warehouse, API, or cloud storage platform
- How to manage data source connections on the Supermetrics Hub
