How to use Data blends and Custom fields in Data Explorer
Data Explorer allows you to shape your results using Supermetrics data blending and custom fields to quickly analyze your marketing directly on the Supermetrics Hub.
Data blending lets you combine data from multiple sources into a single view for more comprehensive analysis. In Data Explorer, you can query your data blends by selecting the Data blend as the data source.
Custom fields enable you to create new metrics or dimensions tailored to your reporting needs. In Data Explorer, you can find the custom fields by selecting the data source for which you created the custom field. The custom fields are under the custom fields category in the metrics or dimensions, depending on the type of field you created.
Before you begin, you'll need to create your Data blend or configure your Custom fields before attempting to use them in Data Explorer. You'll find instructions on how to create Data blends on this Data blending article, and you can learn more about Custom fields and their use cases in the Custom field articles.
Find Data blends in Data Explorer
  1. On the Supermetrics Hub, select Data Explorer from the sidebar and click Explore my data.
  2. In the sidebar, click Data source.
    Select Data Blending as the source, and click Next.
  3. In the sidebar, click Date range and select a preset (such as Last 7 days or This year to date). You can also define a custom date range.
  4. Click Fields and select metrics and dimensions.
  5. Click Filters to add any optional filters.
  6. Click Sort & limit (optional).
  7. Click Options to adjust connector-specific options, if available. Options vary by data source.
  8. At the bottom of the sidebar, click Load data. The table will populate with your selected metrics and dimensions.
Select Custom fields in Data Explorer
    1. Select the data source to use, and click Next.
    2. Select the connection to use, and click Next
    3. Select the accounts to use, and click Next.
  4. Click Fields. Custom fields are listed in the Custom fields categories in the metrics or dimensions.
