Use this guide to connect Google Trends data to your Supermetrics reports.
Google Trends is a publicly available data source, so you don't need an account or any special permissions to access it.
Use it to:
- Inspect the popularity of one or multiple Google search terms over time
- Compare up to 50 search terms at once
- Inspect search term popularity by geolocation
- Fetch trending searches by country
- Fetch data by search term or by topic
Search volume is returned as a relative metric, where 100 represents the highest volume within the time range selected.
Query topics in Google Trends
In Google Trends, you can search for a specific search term or a topic that contains multiple search terms. Explore Google's documentation to learn about the difference between search terms and topics.
To query for a topic, you need to get a unique identifier called topic code for the topic you want to query. Follow these steps to find the topic code and build a query for a topic:
- Search for a topic on Google Trends.
- Copy the topic code from the browser's URL bar — this is the last section of the URL, beginning with a % symbol after a comma or equal sign (=). See the screenshot below.
In this example, the topic code starts after the comma. Note that the search term isn't encoded, which makes it different from a topic.
If you have searched for one topic only, the topic code starts with the % symbol that follows the equal sign. - Decode the topic code. Sites like URL Decoder are helpful for this.
- Insert the decoded topic code into the Search term field in Supermetrics when you're creating your query.
- Navigate to Extensions→ Supermetrics → Launch sidebar to open Supermetrics.
- Under Data source, select Google Trends.
- Click Report configuration.
- Select Query type.
- Select Search by term. Enter the search term or topic code (see Query topics in Google Trends above) for each search term you'd like to query, separated by a comma with no whitespace (,).
- Navigate to Google Trends and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Google Trends requires authorization to connect to data").
