Great to have you here! Follow these steps to get started with Supermetrics for data warehouse destinations.
- First, start a 14-day free trial for Supermetrics for the data warehouse destination of your choice, unless you have already done so.
- Next, log in to the Supermetrics Hub, and configure your data warehouse destination. If you're connecting to BigQuery (marketplace), follow these instructions.
- The next step is to create your first transfer and start pulling data! For BigQuery (marketplace), follow these instructions.
Take a look at our data source connection guides for the details you need to connect.
The following video highlights the main steps for connecting to a data warehouse destination from the Supermetrics Hub.
Learn more
Explore also the articles on using Supermetrics with data warehouse destinations to deepen your knowledge with relevant topics.
To get the most out of your data sources, take a look at our report building and query setup guides.
If you're having issues with a data source, check out the reauthentication guide and articles related to the data source.
Reach out to our support team if you can't find an answer to solve your issue.
Happy reporting!
