Use this guide to connect Vimeo Public Data to Supermetrics.
Vimeo Public Data allows you to collect publicly available data about content on Vimeo. It doesn't require you to log in to a specific account.
- User data: Account metadata
- Video data: Video metadata and basic metrics
- Video uploads: Video metadata and basic metrics from a specific account
- Click Create query.
- Under Data source, select Vimeo Public Data.
- Select your query type, and add your keywords or users.
- Navigate to Vimeo Public Data and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Vimeo Public Data requires authorization to connect to data").
