Use this guide to connect Tripadvisor Reviews to Supermetrics and pull up to 50 of a business' most recent reviews.
You need a business' location ID before you can pull its review data from Tripadvisor Reviews.
You can find any location ID by copying the 7-digit code that follows the -d in any business' Tripadvisor URL.
For example, if a venue's URL ended with /Restaurant_Review-g123456-d7891011-Reviews-Example_venue.html, the location ID would be 7891011.
- Click Create query.
- Under Data source, select Tripadvisor Reviews.
- Enter the business' location ID.
- Navigate to Tripadvisor Reviews and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Tripadvisor Reviews requires authorization to connect to data").
