How to swap data sources
If your Supermetrics subscription is paid using a credit card, you can swap the data sources included in your subscription. Supermetrics allows one data source swap every 30 days.
To enable swapping data sources, you'll need to upgrade your subscription to our latest package. The upgrade ensures compatibility and access to all of our latest features, including swapping data sources.
Note
Note that when you swap a data source to another one, you'll lose access to the data source you're swapping from and your queries will stop working.
For example, if you've been using TikTok Ads, but want to swap that data source to Instagram Insights, your TikTok Ads queries will stop working when you swap.
  1. Go to the Subscriptions page on the Supermetrics Hub. Check from the top bar that you're in the right team.
  2. Select a subscription you want to modify.
  3. Scroll down to Data sources and accounts.
  4. Click Swap data sources.
  5. Select the data source that you want to swap.
  6. Select your new data source and click Next.
  7. Read the terms and check the checkbox to confirm that you agree to the terms, and click Confirm swap.
Contact our support team if you're unable to swap data sources.
