This guide contains all permissions and requirements for connecting your Lazada Commerce data to Supermetrics.
To connect your Lazada Commerce data to Supermetrics, you need a Lazada Commerce account.
- Orders: Pull all the order dimensions and metrics from Lazada Commerce, based on the dataset selected.
When connecting to Lazada Commerce, you need to log in to Lazada and select the accounts to pull data from.
- Select the Lazada Commerce data source on the Supermetrics Hub or in the data destination.
- Select the Lazada Site location from the dropdown menu.
- Log in with the account you use to log in to Lazada.
- Click Submit.
- In your data destination, select the accounts to include in your reporting and a query type, if prompted.
You can also connect to Lazada Commerce from these destinations:
