This guide contains all permissions and requirements for connecting your Google PageSpeed Insights data to Supermetrics.
The Google PageSpeed Insights data source connector doesn't require you to log in to a specific account.
- PageSpeed Insights
When connecting to Google PageSpeed Insights, you need to enter at least one URL to query.
- Select the Google PageSpeed Insights data source on the Supermetrics Hub or in the data destination.
- In your data destination, enter at least one web page URL to query and select the device type (desktop of mobile). Make sure to include also the http:// or https:// part of the URL.
You can also connect to Google PageSpeed Insights from these destinations:
