This guide contains all permissions and requirements for connecting your Zoho CRM data to Supermetrics.
You need to create an application to connect your Zoho CRM data to Supermetrics.
- Go to Zoho Developer Console
- Choose client type: Client-based Applications
- Enter “supermetrics” for Client Name
- Enter “supermetrics.com” for Homepage URL
- Enter https://supermetrics.com/login-complete for Authorized Redirect URIs
To learn more, please go to: https://www.zoho.com/crm/developer/docs/api/v7/register-client.html
When connecting to the Zoho CRM, you need to select a query type. The query type defines the metrics and dimensions available.
- Leads report provides data on the status and performance of your sales leads
- Deals report provides data on the progress and performance of your sales deals
- Select the Zoho CRM data source on the Supermetrics Hub or in the data destination.
- Insert Client ID and Client secret.
- Sign in to your Zoho account.
- Accept scopes for the application.
- If prompted, choose to make this connection shared or private
- Click Start
You can also connect to Zoho CRM from these destinations:
- How to reauthenticate a data source in Looker Studio, Google Sheets, or Excel
- How to reauthenticate a data source in data warehouse, API, or cloud storage platform
- How to manage data source connections on the Supermetrics Hub
