Pinterest Organic connection guide
Follow these steps to connect your Pinterest Organic data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
Note
We released a new version of the Pinterest Organic data source connector on June 1, 2023, with some changes to the authentication process. Learn more about authentication for the new Pinterest Organic data source connector.
To connect to Pinterest Organic, you need a Pinterest business account and an ad account.
With a Pinterest business account and ad account, you can fetch organic data for your own Pinterest profile. Before starting the connection process in Supermetrics, make sure that you're logged into a Pinterest business account in your web browser and not a personal Pinterest account.
Important about authentication
When authenticating, if you receive an error saying We did not find any accounts, please make sure you have created an ad account for your Pinterest business account.
Employee and Partner access
To fetch organic data for another Pinterest account, you must be added as an Employee or Partner to their business account and have at least Analyst access to one of their ad account.
  • Profile: Get aggregated organic metrics of all pins and lifetime metrics of the profile. This report contains analytics from your owned pins (created and saved by you), as well as pins created and saved by others from your claimed accounts, such as websites.
  • Top pins: Get organic metrics for the top 50 pins. This report contains analytics from your owned pins (created and saved by you), as well as pins created and saved by others from your claimed accounts, such as websites.
  • Owned pins: Get organic metrics for your owned pins (created and saved by you) with daily breakdowns.
  3. Click Create new query.
  4. Under Data source, select Pinterest Organic.
  6. Click Start.
  7. Enter your email address and password, and click Log in.
  8. Click Give access.
  9. Select the accounts you'd like to include in your reporting.
  10. Navigate to Report configuration and select a query type.
  2. Navigate to Pinterest Organic and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Pinterest Organic requires authorization to connect to data").
  7. Click Start.
  8. Enter your email address and password, and click Log in.
  9. Click Give access.
  10. Select the accounts you'd like to include in your reporting.
  11. Select a query type, and click Next.
  12. In the pane's top right, click Connect.
  13. Click Create report.
  14. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Pinterest Organic.
  5. Click Start.
  6. Enter your email address and password, and click Log in.
  7. Click Give access.
  8. Select the accounts you'd like to include in your reporting.
  9. Navigate to Report configuration and select a query type.
Data warehouse
  3. Click + Create transfer.
  4. Select the Pinterest Organic data source.
  7. Accept the agreement.
  8. Click Authorize with Pinterest Organic.
  9. Click Start.
  10. Enter your email address and password, and click Log in.
  11. Click Give access.
  13. Click Submit.
  14. Click Save.
  3. Click Create new.
  4. Select the Pinterest Organic data source, and click OK.
  7. Click Start.
  11. Click Create transfer.
Power BI
  3. Click Select data source.
  5. Click Start.
  8. Fill in the query details.
The Supermetrics API
  4. Click Select data source.
  5. Select the Pinterest Organic data source.
  6. Click Start.
Supermetrics Hub
  4. Hover over the Pinterest Organic data source, and click Connect.
  5. Click Start.
