Follow these instructions to connect your Newsletter2Go data to your Supermetrics reports.
To connect Newsletter2Go, you need a Newsletter2Go account and an Auth-Key.
How to find your Auth-Key
- Log in to Newsletter2Go.
- Click your account name in the top-right corner.
- Select Account.
- Click the API tab.
- Copy your Auth-Key. Remember to keep it safe.
- Under Data source, select Newsletter2Go.
- Log in to your Newsletter2Go account.
- Enter your Auth-Key.
- Click Allow.
- Navigate to Newsletter2Go and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Newsletter2Go requires authorization to connect to data").
- Click Allow.
- Click Allow.
