Follow these steps to connect your Criteo data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Criteo, you need:
- An API user with a client ID and client secret
- Learn how to generate these in our Criteo permissions guide.
- An app with at least Read access for all elements of the Marketing API. To create these credentials, follow these instructions.
- If you're logged with an old Criteo app, you'll need to log out of Criteo and then log back again. To install a new app, follow these steps.
- Under Data source, select Criteo.
- Enter your Criteo client ID and client secret.
- Navigate to Criteo and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Criteo requires authorization to connect to data").
- Click + Create transfer.
- Select the Criteo data source.
- Accept the agreement.
- Click Authorize with Criteo.
- Click Submit.
- Click Save.
- Select the Criteo data source, and click OK.
- Click Create transfer.
- Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Criteo data source, and click Connect.
