Follow these steps to connect your Clockify data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to Clockify, you need:
- An account with the Admin user role (or higher). Learn more about Clockify user roles and permissions.
- An API key. Remember to keep this safe once you have it. Learn how to generate an API key in Clockify.
- Under Data source, select Clockify.
- Enter your API key.
- Select the accounts you'd like to include in your reports.
- Navigate to Clockify and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Clockify requires authorization to connect to data").
- Click + Create transfer.
- Select the Clockify data source.
- Accept the agreement.
- Click Authorize with Clockify.
- Click Submit.
- Click Save.
Click New transfer. If you haven't created any transfers yet, click Schedule first transfer.
- Select the Clockify data source, and click OK.
- Click Create transfer.
Click Create or edit queries.
Click Select a data source.
- Fill in the query details.
- In the sidebar, click API.
- Click Select data source.
- Hover over the Clockify data source, and click Connect.
