How to fix “File not found” errors with scheduled refreshes in Google Sheets
If you see this error when running scheduled refreshes in your Supermetrics reports in Google Sheets, there are some steps you can take to troubleshoot the issue.
  • Last Status: Error: Email failed File not found
Check file ownership
Only the owner of the file can set and run Supermetrics scheduled emails.
Make sure your account has Owner access to the file.
Check file location
If the Google Sheets file has been moved to another location or another Google Drive, it can break the connection between the file and Supermetrics' scheduled report refreshes.
To check if the file and its Supermetrics refreshes are still connected, open the Supermetrics sidebar, go to the Schedules tab, and scroll down to click View all schedules in all spreadsheets
If you can't see the scheduled refresh in the list, check the file's location, and set up a new scheduled refresh for it.
Check your Google Drive type
Business Drive
If your Supermetrics subscription is linked to a non-business Google Account, but the file is within your Business Drive, it may automatically make the business account the file owner. This would result in the schedule refresh not finding the file.
To resolve this, move the file back to the non-business account's Drive location and create new scheduled refreshes for it, or change the subscription user to the business account.
Team Drive
Team Drive locations don't have the kinds of permissions Supermetrics scheduled reports require.
For this reason, the Google Sheets files that you use with Supermetrics should be housed in the private Google Drive assigned to your subscription holder's Google Account.
