Follow this guide to connect your Yahoo DSP data to your Supermetrics reports.
To connect Supermetrics to Yahoo DSP, you need API access, including a client ID and client secret. Read Yahoo DSP's documentation to learn how to get access.
- Under Data source, select Yahoo DSP.
- Enter your client ID and client secret, and click Start.
- Navigate to Yahoo DSP and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Yahoo DSP requires authorization to connect to data").
