Use this guide to connect your Moz data to your reports with Supermetrics.
Moz allows you to collect publicly available search engine data. To fetch more than 200 rows of data with it, you’ll need to use your own API credentials.
- URL metrics returns metrics for up to 50 URLs.
- Link metrics returns information about links between a target URL and other pages and domains.
For Excel users
- Under Data source, select Moz.
- Navigate to Report configuration, and choose your query type.
- Add URLs to the "Type URL" field. Separate multiple URLs with commas and no whitespace (,).
- Navigate to Moz and click Try.
- Click Authorize.
- If you're connecting Moz for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
