HubSpot report building guide
Use the HubSpot data source connector to see which campaigns are bringing in the most leads and which leads convert to customers. You can pull data such as contacts, companies, deals, campaigns, emails, submitted form details, products, and analytics.
For a full list of metrics and dimensions available in our HubSpot data source connector, take a look at our HubSpot documentation.
Once you’ve connected to HubSpot, you’re ready to create your first queries!
Try these queries
See the number of customers per month
Take a look at how many new customers you've gained this year. In this example, we take a look at the data on a monthly level.
The "Customers" metric shows the number of new customers in the time period.
  1. Set the date range to Year to date.
  2. Select the Customers metric.
  3. Select the Month dimension to split the query results by month.
See contacts per list name
View the number of contacts on your various lists.
The "Contacts" metric shows the number of contacts.
  1. Select the Contacts metric.
  2. Select the List name dimension to split the query results by contact list name.
See form submissions
View the number of form submissions in the past 4 weeks.
The "Form submissions" metric shows the number of form submissions.
  2. Select the Form submissions metric.
  3. Select the Form name and Date dimensions to split the query results by form name and date.
See the number of deals this year
Keep track of how many deals you've gained this year.
The "Deals" metric shows the number of deals.
  2. Select the Deals metric.
See the Supermetrics blog for posts about how the Supermetrics integration with HubSpot enhances data reporting and how to set up the ultimate HubSpot report.
