How to create a Looker Studio report with Supermetrics
This guide walks you through building Looker Studio (formerly Data Studio) reports with Supermetrics. Once you’ve set up your tables and charts, you can set them to update automatically with scheduled refreshes.
Before you set up your first report, you’ll need to connect your data sources to Supermetrics and Looker Studio.
  1. Log in to Looker Studio.
  2. In the top left corner, go to Create → Report. A new report will open.
  3. You can add a data source to the new report from Connect to data tab. This will create an embedded data source that can only be used in this report or from the My data sources tab when creating new reports. If you need to connect a new data source, follow these instructions. Under My data sources, you'll see the data source files you've already created with Supermetrics.
  4. Select the data source you'd like to use, and click Add in the bottom left corner.
  5. A new report will open, and you can start building your charts.
  6. Add a new chart to the report by clicking Add a chart in the report's upper menu.
Take a look at our report building guides for inspiration on your reports!
How to copy a report
Creating a copy of a report allows you to easily share it with others, or use it as a template. Read Google’s documentation to learn how to do this
Note that some elements are part of the data source file, not the report, and won't be copied over unless you also recreate or copy the data source file.
