Integral Ad Science connection guide
Follow these steps to connect your Integral Ad Science data to Supermetrics and use your data in Google Sheets, Looker Studio, Excel, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your Integral Ad Science account, you need the username and password of your Integral Ad Science account.
  • Performance: Report performance of your ad campaigns on campaign, advertiser, team, placement, device or app level.
  3. Click Create new query.
  4. Under Data source, select Integral Ad Science.
  5. Enter your Integral Ad Science username and password.
  7. Click Start.
  2. Navigate to Integral Ad Science and click Start free trial.
  4. Once that's done, or if you've done it before, click the right-hand Authorize button (under "Integral Ad Science requires authorization to connect to data").
  6. Enter your Integral Ad Science username and password.
  8. Click Start.
  9. Select the query type, and click Next.
  10. In the pane's top right, click Connect.
  11. Click Create report.
  12. Click Add to report.
Excel
  1. Open an Excel file.
  3. Under Data source, select Integral Ad Science.
  4. Enter your Integral Ad Science username and password.
  6. Click Start.
Power BI
  3. Click Select data source.
  4. Select the Integral Ad Science data source.
  6. Click Start.
  7. Fill in the query details.
  8. Click Run query to test your query.
The Supermetrics API
  4. Click Select data source.
  5. Select the Integral Ad Science data source.
  7. Click Start.
  8. Fill in the query details. See detailed instructions on how to set up a Supermetrics API query in Query Manager.
  9. Click Run to test your query.
Supermetrics Hub
  4. Hover over the Integral Ad Science data source, and click Connect.
  6. Click Start.
