Yandex.Direct & Yandex.Metrica connection guide
This guide contains all permissions and requirements for connecting your Yandex.Direct and Yandex.Metrica data to Supermetrics.
To connect Yandex data sources, you need Chief Representative or Representative user access. Learn more about Yandex user roles.
When connecting to Yandex.Direct or Yandex.Metrica, you need to log in to Yandex.
  1. Select the Yandex.Direct or Yandex.Metrica data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your credentials, and click Log in.
  5. Click Allow.
You can also connect to Yandex.Direct and Yandex.Metrica from these destinations:
