Pinterest Ads and Pinterest Organic connection guide
Use this guide to connect Pinterest Ads or Pinterest Organic to Supermetrics.
Your Pinterest accounts need specific permissions before they can connect to Supermetrics.
  • To connect to Pinterest Ads, you need a Pinterest user account with at least Admin or Campaign access to an ad account.
  • To connect to Pinterest Organic, you need to log in with the profile's Owner account. Note that Supermetrics can only pull data from business profiles.
Google Sheets Looker StudioExcel
  3. Click Create query.
  4. Under Data source, select Pinterest Ads or Pinterest Organic.
  5. Click Start.
  6. Enter your email address and password, and click Log in.
  7. Click Give access.
  8. Select the accounts you'd like to include in your reporting.
  9. For Pinterest Organic, navigate to Report configuration and select a query type.
