Amazon Ad Server (Sizmek) connection guide
This guide contains all permissions and requirements for connecting your Amazon Ad Server (Sizmek) data to Supermetrics.
Before using the Amazon Ad Server (Sizmek) connector, you need to sign an API agreement with Amazon Ad Server (Sizmek) allowing Supermetrics to access your account via API. This can be done through your Amazon Ad Server (Sizmek) client service manager or Amazon Ad Server (Sizmek) customer support. After this, you should receive a username, password, and API key, which are used to connect to the Amazon Ad Server (Sizmek) data source.
Query types define what sort of metrics and dimensions are available. You need to select a query types when pulling data. The Amazon Ad Server (Sizmek) connector has 3 different report types, each providing a different way to report campaign performance:
  • Campaign performance: Report the performance of your ad campaigns on campaign, ad, brand, site, or placement level.
  • Geo performance: Report the performance of your ad campaigns on campaign and country level.
  • Device performance: Report the performance of your ad campaigns on campaign, device, and browser level.
When connecting to Amazon Ad Server (Sizmek), you need to enter your credentials and select the account when prompted.
  1. Select the Amazon Ad Server (Sizmek) data source on the Supermetrics Hub or in the data destination.
  2. Enter the username, password, and API key you received from your Amazon Ad Server (Sizmek) account manager.
  4. Click Start.
  5. In your data destination, select the account to pull data from.
You can also connect to Amazon Ad Server (Sizmek) from these destinations:
