Use this guide to connect Reddit Public Data to Supermetrics.
Reddit Public Data allows you to collect publicly available data about Reddit posts. It doesn't require you to log in to a specific account.
- Reddit user data fetches the user metadata for an account.
- Reddit subreddit data fetches a subreddit's metadata.
- Reddit posts fetches post details for a keyword.
For Excel users
- Click Create query.
- Under Data source, select Reddit Public Data.
- Select your query type, and then the keywords, usernames, or other data you want to query.
- Navigate to Reddit Public Data and click Try.
- Click Authorize.
- If you're connecting Reddit Public Data for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
