Once you’ve authenticated your connection to Vkontakte Public Data, you’re ready to create your first query. This guide will walk you through Vkontakte Public Data query setup for Google Sheets, Data Studio, and Microsoft Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
The Supermetrics Vkontakte Public Data data source doesn't need you to log in to a specific account. Therefore, no access requirements are needed for this data source.
Available fields
- Dimensions can be found under type - “dim”.
- Select Metrics.
- Under Options, you can add additional features to your query. Learn more about Supermetrics advanced settings in Google Sheets.
- Select the Date range from the auto or custom options. If you choose a custom date range, click the arrow on the top-right-hand side. Under a specific period, select a Start Date and End Date.
- Select Metrics.
Advanced options for Excel
- Set up BigQuery
- Set up Supermetrics API
If you see an error about metrics and dimensions not fetching together, or fields being incompatible, follow these steps to fix the issue.
If you see errors relating to quotas, or “daily query quotas”, read this guide.
