Use this guide to connect VKontakte Public Data to Supermetrics.
- VKontakte posts: Returns metadata on public posts that match your keyword, as well as basic metrics including counts of comments, likes, and more.
- VKontakte user data: Returns public username and metadata about users, including the number of friends, videos, or photos from their account.
For Excel users
- Click Create query.
- Under Data source, select VKontakte Public Data.
- Select your query type, and add your keywords or user IDs. If you're adding more than one, separate each term with a comma, or give each one a new line.
- Navigate to VKontakte Public Data and click Try.
- Click Authorize.
- If you're connecting VKontakte Public Data for the first time, log in with the Google Account you use with Supermetrics. Click Allow.
- Click Authorize.
