Once you’ve authenticated your connection to Optimizely, you’re ready to create your first query.
This guide will walk you through Optimizely query setup for Google Sheets, Data Studio, and Excel.
To connect Supermetrics to Optimizely, you need:
- Administrator or Pro user access to an ad account. See Optimizely’s documentation to learn how to grant access.
Here’s an example of sufficient user permissions:
Available fields
- Select Metrics.
- Select Split by Dimensions.
You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted. - Click Get Data to Table to create your query and pull your data.
- Under Options, you can add additional features to your query. Learn more about Supermetrics advanced settings in Google Sheets.
- Select Metrics.
You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted. - Click Get data to create your query and pull your data.
Advanced options for Excel
- Set up BigQuery
- Set up the Supermetrics API
