Optimizely connection guide
This guide contains all permissions and requirements for connecting your Optimizely data to Supermetrics.
To connect Supermetrics to Optimizely, you need Administrator or Pro user access to an ad account. Learn more about granting access in Optimizely's documentation.
When connecting to Optimizely, you need to log in to Optimizely and select the accounts to use.
  1. Select the Optimizely data source on the Supermetrics Hub or in the data destination.
  3. Click Start.
  4. Enter your Optimizely email address and password, and click Log in.
  5. In your data destination, select the accounts you'd like to include in your reporting.
You can also connect to Optimizely from these destinations:
