Optimizely connection guide
Use this guide to connect your Optimizely data to the reports you create with Supermetrics.
To connect Supermetrics to Optimizely, you need Administrator or Pro user access to an ad account. Learn more about granting access in Optimizely's documentation.
Google Sheets LookerExcel
  3. Click Create new query.
  4. Under Data source, select Optimizely.
  5. Click Start.
  6. Enter your Optimizely email address and password, and click Log in.
  7. Select the accounts you'd like to include in your reporting.
