Use this guide to connect Tumblr Public Data to Supermetrics.
- Click Create query.
- Under Data source, select Tumblr Public Data.
- Select your query type, and add your tags or usernames. If you're adding more than one, separate each term with a comma, or give each one a new line.
- Navigate to Tumblr Public Data and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Tumblr Public Data requires authorization to connect to data").
