Reddit Public Data report building guide
Use the Reddit Public Data data source connector to get data about posts, sub reddits, and account details. You can report the number of posts a specific keyword has generated over time and see the engagement on the posts where your keyword is used.
For a full list of metrics and dimensions available in our Reddit Public Data data source connector, take a look at our Reddit Public Data documentation.
Once you’ve connected to Reddit Public Data, you're ready to create your first queries!
When connecting to the Reddit Public Data data source, you need to select a query type. The query type defines what sort of metrics and dimensions are available.
  • Reddit user data: Fetches the user metadata for an account.
  • Reddit subreddit data: Fetches a subreddit's metadata.
  • Reddit posts: Fetches post details for a keyword.
Try these queries
See upvotes for posts
Take a look at the upvotes for posts with a particular keyword. In this example, we take a look at the upvotes data for the previous month.
Use the "Reddit posts" query type.
The "Upvotes" metric shows the number of upvotes.
  1. Select the Reddit posts query type and specify the keyword to query.
  2. Set the date range to Last month.
  3. Select the Upvotes metric.
  4. Select the Date dimension to split the query results by date.
See comments and upvotes
Stay on top of the comments and upvotes for particular keywords. Here, we take a look at the comments and upvotes, and also include the date when the comment was posted, link to the comment, the subreddit the comment was posted in, and the title of the post.
The "Comments" metric shows the number of comments.
  2. Set the date range to Last week.
  3. Select the Comments and Upvotes metrics.
  4. Select the Date, Link to comments, Subreddit, and Title dimensions to split the query results by these details.
See posts per subreddit
Take a look at which subreddit the posts about your keyword are being posted into.
The "Posts" metric shows the number of posts.
  3. Select the Posts metric.
  4. Select the Subreddit dimension to split the query results by subreddit name.
See post details
View the number of posts, upvotes, downvotes, gilded posts, number of comments, and view count for posts around the particular topic you're interested in. In this example, we take a look at the data by date for the ongoing month.
The "Downvotes" metric shows the number of downvotes.
The "Gilded" metric shows the number of gilded posts.
  2. Set the date range to This month to date.
  3. Select the Posts, Comments, Upvotes, Downvotes, Gilded, and Views metrics.
