Follow these steps to connect your MediaMath data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect Supermetrics to your MediaMath account, you need a MediaMath account.
- Campaign performance: Examine the performance of campaigns and strategies by a number of dimensions (such as Exchange, Creative, and Deals) and metrics (impressions, CPA, CPC) to make more nuanced optimizations across channels.
- Under Data source, select MediaMath.
- Log in with the account you use to log in to MediaMath.
- Click Agree.
- Navigate to MediaMath and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "MediaMath requires authorization to connect to data").
- Click Agree.
- Select the query type.
- Click Next.
- Click Agree.
- Click + Create transfer.
- Select the MediaMath data source.
- Accept the agreement.
- Click Authorize with MediaMath.
- Click Agree.
- Click Submit.
- Click Save.
- Click Create new.
- Select the MediaMath data source, and click OK.
- Click Agree.
- Click Create transfer.
- Click Select data source.
- Click Agree.
- Fill in the query details.
- Click Agree.
- Hover over the MediaMath data source, and click Connect.
- Click Agree.
