Yelp Reviews: Query setup guide
Once you’ve connected Supermetrics to Yelp Reviews, you’re ready to create your first query.
This guide will walk you through Yelp Reviews query setup for Google Sheets, Looker Studio (formerly Data Studio), and Excel.
Available fields
Visit our documentation site for a full list of the metrics and dimensions Supermetrics can pull from Yelp Reviews
Google Sheets Looker Studio Excel
  1. Connect Supermetrics to Yelp Reviews in Google Sheets
  2. Enter the Yelp Business ID in the Yelp Business ID field.
  3. Select Dates. Choose one date range (today, yesterday, last week, etc.). To select a custom date, you can insert the date manually in the Start and End fields in the calendar bar.
  4. Select Metrics
  5. Select Split by Dimensions.
    You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted.
  6. Click Get Data to Table to create your query and pull your data.
