Use this guide to connect your Facebook Political Ads data to Supermetrics.
To connect Supermetrics to Facebook Political Ads, you need to:
- Confirm your identity on Facebook
- Register as a Facebook developer and create a developer application
- Click Create query.
- Under Data source, select Facebook Political Ads.
- Enter your App ID and App Secret. Learn how to find these credentials.
- Navigate to Facebook Political Ads and click Try.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Facebook Political Ads requires authorization to connect to data").
