Once you’ve authenticated your connection to Awin, you’re ready to create your first query.
This guide will walk you through how to create your first Awin query in Google Sheets, Data Studio, or Excel.
Awin metrics and dimensions
We’re happy to offer a wide range of Awin fields in Supermetrics. You can review a full list of these in our technical documentation.
- Authenticate Awin in Google Sheets.
- In the Supermetrics sidebar, select a date range for your query. If you need to query a lot of historical data, consider using the “Combine new results with old” feature.
- Select your query’s metrics and dimensions. If you’d like some inspiration or a starting point, take a look at our Google Sheets templates.
- Authenticate Awin in Data Studio.
- Select your query’s metrics and dimensions. If you’d like some inspiration or a starting point, take a look at our Data Studio templates.
- Your data will fill out the charts you select automatically.
When you’re ready, learn how to use filters and data blending to further refine your reporting. You can also optimize your Data Studio reports to keep them running quickly and smoothly.
- Authenticate Awin in Excel.
- Select your query’s metrics and dimensions. If you’d like some inspiration or a starting point, take a look at our Excel templates.
When you’re ready, learn how to use Excel’s advanced settings to further refine your reporting.
You can also set up scheduled refreshes so your queries update automatically. These refreshes also deliver reports directly to your inbox on a schedule that works for you.
- If you see errors relating to quotas or daily query quotas, learn more in our quotas and usage guide.
