Tripadvisor Reviews: Query setup guide
Once you’ve authenticated your connection to Tripadvisor Reviews, you’re ready to create your first query. This guide will walk you through Tripadvisor Reviews query setup for Google Sheets, Data Studio, and Microsoft Excel.
To connect Supermetrics to Tripadvisor Reviews, you need:
  • Location ID of the venue from which you want to get data.
Your TripAdvisor ID is a numerical ID located in the URL of the TripAdvisor profile page. An easy way to find it is by searching for the ID number after the letter “d” in the TripAdvisor listing URL, see example below:
  • It doesn't require logging into a user account, therefore, no permissions are required for this data source.
Location reviews
Please note that you can fetch up to 50 latest reviews (not more) for your locations.
Available fields
  • Dimensions can be found under type - “dim”.
Google Sheets Data Studio Excel Data Integrations
  1. Authenticate the data source in Google Sheets.
  2. Select Metrics
  3. Select Split by Dimensions. You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted.
  4. Click Get Data to Table to create your query and pull your data.
If you see an error about metrics and dimensions not fetching together, or fields being incompatible, follow these steps to fix the issue.
If you see errors relating to quotas, or “daily query quotas”, read this guide.
