How to query for specific conversions in LinkedIn Ads
If you want to query for specific conversion types in LinkedIn Ads data, follow the example below.
Use this basic query setup to get the types of conversions that your LinkedIn Ads campaigns are using.
  • Metrics: Conversions
  • Dimension: Conversion type
Setup in the Supermetrics sidebar that pulls the "Conversions" metric and "Conversion Type" dimension.
Note on field compatibility
Many other metrics are not compatible with the Conversion-specific dimension, so you won't be able to query them at the same time (they may return an error or will be empty values). The API’s setup means that you can’t request other dimensions, or get a join key.
