Adtraction: Query setup guide
Once you’ve authenticated your connection to Adtraction, you’re ready to create your first query.
This guide will walk you through how to create your first Adtraction query in Google Sheets, Looker Studio (formerly Data Studio), or Excel.
Adtraction metrics and dimensions
We’re happy to offer a wide range of Adtraction fields in Supermetrics. You can review a full list of these in our technical documentation.
Google Sheets Looker Studio Excel
  1. Authenticate Adtraction in Google Sheets.
  2. In the Supermetrics sidebar, select a date range for your query. If you need to query a lot of historical data, consider using the “Combine new results with old” feature.
  3. Select your query’s metrics and dimensions. If you’d like some inspiration or a starting point, take a look at our Google Sheets templates.
  4. Click Get Data to Table to create your query and pull your data.
