Zemanta connection guide
Follow these steps to connect your Zemanta data to Supermetrics.
To connect Supermetrics to your Zemanta account, you need to create a Client ID and Client Secret.
Create Client ID and Client secret
  1. Log in to Zemanta using this link.
  2. Click New Application.
  3. Enter a name for the application, for example, “Supermetrics”.
  4. Click Save.
  5. Copy the Client ID and Client secret and store them in a secure place for later use.
  • Performance: Measure the performance of your campaigns in Zemanta.
Google Sheets Looker StudioExcel
  3. Click Create new query.
  4. Under Data source, select Zemanta.
  5. Enter your Client ID and Client secret.
  6. Enter a name for your account for you to identify it later.
  7. Click Start.
