Use the Clockify data source connector to track time spent on different tasks by reporting all the time entries added to Clockify. Fetch data by time, by user, by client or by project and see what is the effective billing rate across your employees and projects.
For a full list of metrics and dimensions available in our Clockify data source connector, take a look at our Clockify documentation.
Once you’ve connected to Clockify, you're ready to create your first queries!
Try these queries
See time entries for last week
Take a look at the duration of the time entries for last week. Here, we split the data by the start date of the time entry.
The "Duration (h)" metric shows the duration of the time entry in hours.
- Select the Duration (h) metric.
- Select the Entry start date dimension to split the query results by the start date of the time entry.
See billable hours
In this example, we take a look at the duration of time entries and the amount of billable hours for last month. We also compare this data to the previous month.
The "Amount" metric shows the rounded value of the billable amount of the time entry.
- Set the date range to Last month.
- Select the Amount and Duration (h) metrics.
- Set the Comparison date range to Previous period.
See billable hours with project name and description
Take a look at the billable hours compared to all hours, along with the time entry description and task ID. In this example, we look at the data for the ongoing month.
- Set the date range to This month to date.
- Select the Description and Task ID dimensions to split the query results by these details.
