Follow these steps to connect your Searchmetrics data to Supermetrics and use your data in any of our data destinations — Google Sheets, Looker Studio, Excel, data warehouses, and Power BI, as well as the Supermetrics API. You can also connect to data sources from the Supermetrics Hub.
To connect to Supermetrics, your Searchmetrics account needs:
- Administrator access
- An API key and API secret
- Export credits
- Every data request costs Searchmetrics export credits, even when you're just testing queries. Learn more about this in Searchmetrics' API documentation.
- Under Data source, select Searchmetrics.
- Enter your API key and API secret.
- Navigate to Report configuration, and select your query type.
- Add URLs in the Type URL field, separated by new lines or commas with no whitespace (,).
- Select a country.
- Navigate to Searchmetrics and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Searchmetrics requires authorization to connect to data").
- Select a country.
- Select a country.
- Click + Create transfer.
- Select the Searchmetrics data source.
- Accept the agreement.
- Click Authorize with Searchmetrics.
- Click Submit.
- Click Save.
- Click Create new.
- Select the Searchmetrics data source, and click OK.
- Click Create transfer.
- Click Select data source.
- Fill in the query details.
- Hover over the Searchmetrics data source, and click Connect.
