Once you’ve authenticated your connection to Reddit Public Data, you’re ready to create your first query. This guide will walk you through Reddit Public Data query setup for Google Sheets, Looker Studio (formerly Data Studio), and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
Reddit Public Data allows you to collect publicly available data about Reddit posts. It doesn't require you to log in to a specific account.
Available fields
- Dimensions can be found under type - “dim”.
- Select Metrics.
- Under Options, you can add additional features to your query. Learn more about Supermetrics advanced settings in Google Sheets.
- Authenticate the data source in Looker Studio.
- Select the Date range from the auto or custom options. If you choose a custom date range, click the arrow on the top-right-hand side. Under a specific period, select a Start Date and End Date.
Advanced options for Looker Studio
- Select Metrics.
Advanced options for Excel
- Set up BigQuery
- Set up Supermetrics API
If you see an error about metrics and dimensions not fetching together, or fields being incompatible, follow these steps to fix the issue.
If you see errors relating to quotas, or “daily query quotas”, read this guide.
