Follow these steps to add new connections or data source accounts to the Looker Studio (formerly Data Studio) reports you create with Supermetrics.
To add user accounts:
- Click the Edit icon next to your data source (or click Resource → Managed added data sources and click Edit there).
- Click Edit connection.
In the data source settings, click on the link at the end of the sentence that starts with “To add more/manage user accounts…”
If you belong to multiple teams, you'll be asked to select one. Choose the team you'd like to add the new account to.
Click + Add connection to add a new user account.
To add multiple accounts:
- In Looker Studio's top menu, navigate to Resource → Manage added data sources.
- Find the data source you want to add more accounts to in the list and click Edit.
- Under Select accounts (this might also read Select pages or Select profiles, for example, depending on your data source) and choose the accounts you'd like to add.
- Click Reconnect.
- Click Done.
