Yahoo DSP: Query setup guide
Once you’ve authenticated your connection to Yahoo DSP, you’re ready to create your first query.
This guide will walk you through Yahoo DSP query setup for Google Sheets, Looker Studio (formerly Data Studio), and Excel, as well as data warehouse destinations like Google Cloud Storage, BigQuery, and the Supermetrics API.
To connect Supermetrics to Yahoo DSP, you need:
  • API access and a Client ID and Client secret. To enable the API, please follow the One-time setup steps.
Available fields
Visit our documentation site for a full list of the metrics and dimensions Supermetrics can pull from the data source
Google Sheets Looker Studio Excel Data Integrations
  1. Authenticate the data source in Google Sheets.
  2. Select Metrics
  3. Select Split by Dimensions. You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted.
  4. Click Get Data to Table to create your query and pull your data.
  2. Under Options, you can add additional features to your query.
  • Replace blank metric values with zeros.
  • Combine new results with old.
  • Format results for Looker Studio (to import data from Google Sheets to Looker Studio).
  • No header row.
  • Highlight values with colours (green, red, etc.).
  • Advanced settings.
