Omnisend: Query setup guide
Once you’ve authenticated your connection to Omnisend, you’re ready to create your first query. This guide will walk you through Omnisend query setup for Google Sheets, Looker Studio (formerly Data Studio), and Excel.
To connect Supermetrics to Omnisend, you need:
Available fields
Visit our documentation site for a full list of the metrics and dimensions Supermetrics can pull from the data source
Google Sheets Looker Studio Excel Data Integrations
  1. Authenticate the data source in Google Sheets
  2. Select Dates. Choose one date range (today, yesterday, last week, etc.). To select a custom date, you can insert the date manually in the Start and End fields in the calendar bar.
  3. Select Metrics
  4. Select Split by Dimensions.
    You can choose to split your data into rows and/or columns, reflect the number of rows or columns to be fetched, and define how the data is sorted.
  5. Click Get Data to Table to create your query and pull your data.
