Use this guide to connect your Sizmek data to Supermetrics.
Before using the Sizmek connector, you need to sign an API agreement with Sizmek allowing Supermetrics to access your account via API. This can be done through your Sizmek client service manager or Sizmek customer support. After this, you should receive a username, password, and API key which are used to connect to the Sizmek data source.
Sizmek connector has 3 different report types providing you with different ways to report the performance of your campaigns.
- Campaign performance: Report performance of your ad campaigns on campaign, ad, brand, site or placement level.
- Geo performance: Report performance of your ad campaigns on campaign and country level.
- Device performance: Report performance of your ad campaigns on campaign, device and browser level.
- Navigate to Supermetrics → Launch sidebar to open Supermetrics.
- Under Data source, select Sizmek.
- Enter the username, password and API key you received from your Sizmek account manager.
- Select a query type.
- Navigate to Sizmek and click Start free trial.
- Once that's done, or if you've done it before, click the right-hand Authorize button (under "Sizmek requires authorization to connect to data").
